Cylinder #1 not firing
1988 325 ix. Car has been running terrible, lacking power and running rough. I changed all plugs, writes, coil, distributor and rotor. After driving for a while I pulled all the plugs and all but #1 looked normal. #1 was wet with fuel and did not have any color changing signs of ignition. I grounded the plug and observed a spark on the plug while connected to the ignition wire so it seems to have spark. I also ran a compression test and all cylinders checked out over 145 psi.
Do I not have enough fuel? Clogged injector?
If I let the engine run like this I also hear some popping every so often like a backfire but more of a pop through intake side.
Any help?
Any help?
