Car does not idle, but will rev and drive (but misses)
  • RP808
    • Mar 2014
    • 17
    Hi all. Damn! I don't feel so bad now that it looks like a lot of people are having idle issues!
    The other day I was driving leisurely down the road maintaining a steady throttle, going 35mph in second I believe, when the fueling cut out. It dropped momentarily (from 4k rpm or so to less than 1k) and then picked back up. It reminded me of a Honda vtec at that moment when you let off the gas just as the vtec switches from 4 valves to 2 but only a lot more evident.
    I thought nothing of it, maybe bad gas and drove my car around for several more days, until...
    Today while going to the bank, my car just flat out came to a sputtering stop. Engine light went on, even. I managed to fire it back up but it would not idle, or at best it did very roughly. When I pressed the accelerator and increased revs it evened out somewhat although it was missing and sputtering. I managed to get it back home and noticed the smell of gasoline. I tried to start it again and it idled for a moment and then died. It wants to idle but in a loping fashion that causes all the warning lights to phase in and out. I am going to check battery connection, plugs, idle stabilizer and AFM in the morning but thought I would post this in case anyone can add any insight into my predicament. Thank you in advance.
    1988 325is
    5 speed
    155k miles
    K&N intake
    Chipped
  • RP808
    • Mar 2014
    • 17
    PS. It always idled fine (cold) on start up. But then it would wander in rpms as it warmed up. Once it was warm the idle was fine (not always perfect; at times it seemed to be uneven as if there was an exhaust leak), but I did notice that it could have been smoother.
    1988 325is
    5 speed
    155k miles
    K&N intake
    Chipped
      The action of the tachometer in the first event sounds like a failing CPS, which could also cause the other problems.
      • RP808
        • Mar 2014
        • 17
        Thank you I will check on that. As it turns out my car came with some spare parts so I changed out the AFM twice as well as the idle stabilizer and still nothing. I then pulled the plugs and found every one of them fouled, but they were NGK rubbish so will soon be replaced. Working my way back toward the fuel tank I decided to change the fuel filter as I had 3 spares. I also noticed that the one that was in there was at least 20 years old! That seemed to be the issue. The car started and ran. I took it for a spin and it seems normal although I think that I may need to adjust fuel mix.
        1988 325is
        5 speed
        155k miles
        K&N intake
        Chipped
        • AndrewBird
          The Mad Scientist
          • 11897
          FYI, assuming they were the correct plugs, NGKs are good plugs. Those or Bosch coppers (NOT platinums) are the preferred plug for an M20.
