M20 Crank; No Spark
  • a vvhiteman
    • May 2013
    • 30
    M20 Crank; No Spark
    Ran through JLevie's informative post as to what is needed for the m20 to run. When checking the DME grounds (pins 2,14,19,24), Voltage is present on all. All other tests checked out fine. What would be the next step in chasing down this problem? Thanks in advance for the help!
    Check the DME ground wire connection on the right strut tower.
    • a vvhiteman
      • May 2013
      • 30
      Thanks for the fast reply! Turns out when I swapped a different harness I had the dme ground in the wrong spot (it was late)... Now I have spark but it's an orange color as opposed to the blue I should be seeing. Any idea where to look next? Appreciate the help as this is my first venture into electrical issues.
      • dnguyen1963
        • Nov 2011
        • 2651
        If you have weak sparks then check your ignition coil.
