Hello,
Have troubles getting spark on my 325e 86 motor swap into a 318i 90 shell.
Have swapped over:
motor
gearbox
diff
tailshaft
exhaust
ecu
cluster
loom
rear battery wiring
new parts:
coil
belts
rotor
dizzy cap
gaskets - rocker cover, inlet manifold, exhaust, throttle body.
As far as i know i have swapped everything i need from my donor car (old week car) into the shell.
Having troubles getting good spark on all cylinders.
Got yellow spark on 1 and 6 sometimes fires.
No spark on the plugs from 2,3,4 and 5.
Have checked all the leads and plugs and they are all doing the same in different places.
Getting spark off the coil.
We have new fuel, working pump etc. NOT A FUEL PROBLEM.
have checked the reference sensor and speed sensor both seem to be working fine and worked in the old car. tried switching plugs etc didnt help.
check the ecu and pins on the loom all check out
rewired the C101 plug (engine loom to fuse box plug) to make sure 100% right.
Rewired the 3 plug next to the ecu (same as donor car)
did a full ignition check and couldnt find anything.
Any ideas on what this could be, I still have heaps of things we have tried with no change.
thanks for any help.
Have swapped over:
motor
gearbox
diff
tailshaft
exhaust
ecu
cluster
loom
rear battery wiring
new parts:
coil
belts
rotor
dizzy cap
