327i Questions
  • E30Nick325
    • Mar 2014
    • 56
    327i Questions
    Couple questions pertaining to an I head swap on my eta. Does anyone have the bolt specs for the cps mounting bracket? And do i need to do any wiring modifications? My buddy had a square c101 connector and said he had to make an adapter, but i have a round one. Not sure if theres any difference through the years. He said dont catch my car on fire so a little cautious about it now.
    Thanks,
    Nick
    Feedback: http://www.r3vlimited.com/board/showthread.php?t=326498
    • 37833
    There is plenty of info on the subject here in the M20 section. Please use the search function.
    Your friend is right, you'll want to make an adapter from square to round. Diagrams are on R3V as well.
    For the CPS bracket and bolts you can find the part numbers on RealOem.com
    Grover Beach, California
    BimmerHeads.com
    • E30Nick325
      • Mar 2014
      • 56
      I have the round connector, not the square. My question was if there were different pinouts for the round connector through different years, such as early/late. And I looked on RealOEM and there was only specs for one bolt that I could find. M8x25, I thought there were two to mount the bracket and I'm not sure if they're the same.
      Also, thank you for moving this, I was iffy on where to post it seeing as the c101 connector question is electrical.
