Bought the car originally from a guy for $700. 86 325e 5 speed, very clean car however when i bought it, it wasn't running. I got the car running, happened to be fuel pumps. Im trying to get this car registered and on the road. The issue I'm having is it has almost a major leak or misfire or something, idles fine, once in awhile it will be weird but the car has a power loss. I put the car in gear and go and once i hit 2k rpm it just drops as if the car is going to shut off. I can't rev past that or anything. Once in a while when the car is in neutral i can rev it higher than 2k but it still skips at a higher rpm. I am offering a reward to who ever helps me figure this out because i need this car 100% and i cannot find the reason why to save my life. I guess this is why they say don't buy other peoples projects.. but its a great looking car. Ive replaced the following, TPS,AFM,DME,FPR,ICV,CPS,Plugs,Distributer,Rotor, and injectors however the injectors were out of my buddies parts car so they are used. Any ideas? Car won't accelerate pass 2k RPM. HELP! Thanks!!
Please help me! e30 325e.
88' E30 325 24v Turbo Coupe
91' E30 325i Sedan
09' E82 135i Coupe (Sold)
01' E46 325ci Coupe (Sold)
97' E36 328is Coupe (Sold)
91' E30 325i m52 Coupe (Sold)
90' E30 325is Coupe (Sold)
90' E30 325ic Coupe (Sold)
88' E30 325is m20 Turbo Coupe (Sold)
88' E30 325 Coupe (Sold)
87' E30 325e Coupe (Sold)
86' E30 325es Coupe (Sold)Tags: None -
Anyone?88' E30 325 24v Turbo Coupe
91' E30 325i Sedan
86' E30 325es Coupe (Sold) -
i wrote that i replaced all 3 of those things in the beginging88' E30 325 24v Turbo Coupe
91' E30 325i Sedan
86' E30 325es Coupe (Sold)Comment
coolant temp sensor wouldn't cause this issue i don't think.. now the car just seems like its just hitting fuel cut.. could the injectors i put in be bad or leaky ? All vacuum lines are good and i have pressure at rail.. help!! Also i unplugged o2 sensor to make sure it wasn't a clogged cat88' E30 325 24v Turbo Coupe
91' E30 325i Sedan
anyone have any ideas? i have no clue.. getting so frustrated with this thing88' E30 325 24v Turbo Coupe
91' E30 325i Sedan
Have you watched fuel pressure via a guage while the issue is occurring? If not put a gauge under the wiper blade and watch it while driving when the issue presents itself. And report back your findingsShawn @ Bimmerbuddies
Bimmerbuddies LLC
717-388-1256
2971a Roundtop Rd, Middletown PA 17057
bimmerbuddiesllc@gmail.comComment
did a fuel test and its all smooth. pumps are working, fuel coming out of FPR, fuel is there.. i was thinking vacuum line but it runs fine at idle..88' E30 325 24v Turbo Coupe
91' E30 325i Sedan
Got it all figured out today! thanks for the help !88' E30 325 24v Turbo Coupe
91' E30 325i Sedan
Gas tank kept clogging pump88' E30 325 24v Turbo Coupe
91' E30 325i Sedan
