Oil Everywhere
  • VBe30
    • Oct 2013
    • 173
    Oil Everywhere
    So I've been losing about 1 Quart of oil about every couple of weeks or so. It's time to replace some gaskets.
    I plan on doing the following:
    Oil Pan gasket
    Oil Control Valve Gasket
    I don't see any leaking from the head. What are some other common leaking spots?
    I'll probably put in some new OEM engine mounts while I'm doing the oil pan. Any other stuff I should check/order before I take on this project??
    Much appreciated!
    89' 325is - Alpine
  • Cabriolet
    • 9620
    your rear main seal may be toast as well.
    you need to do rocker shaft plugs as well. $1 each, 4 of them.
    Much wow
    I hate 4 doors
