325i valve springs in 'E' head
  • ENTROPY
    • Apr 2006
    • 4
    I haven't really found too much on this issue. I have a 84' 325E. I want to put the DINAN chip in it I know it raises the RPM. Wanted to prevent severe valve float as I plan to turbocharge in the near future. Need to know how complicated or not it would be to use these springs.
  • rs4pro3
    • 5808
    you just install them, that's it. no mods needed. To do the swap you need both inner and outer I springs, plus the I style upper seats
    85 325e 2.7 ITB'd stroker
    • ENTROPY
      • Apr 2006
      • 4
      Would this upgrade in springs really help? I think the 'E' cam has higher lift than the 325i cam just has a shorter duration. Is this a rather cheap solution to the problem?
      • E30 Wagen
        • ENTROPY
          • Apr 2006
          • 4
          thanks for the info.
