Can someone tell me what I just bought?
  • benjamin
    • 174
    I recently bought my second e30, and I'm a little confused as to what I have. It's badged as a 325e, but all the stuff I'm reading on stricklyeta says the 2.7's have a redline of 4,800. Mine looks like it redlines at 6,250? A thin red line starts at 6,250 and then becomes thicker at 6,500. Is there something I'm missing? Production date is 03/85.
    Thanks for the help!
    Ben
  • kronus
    • Apr 2008
    • 13030
    You probably have a replacement tach from an i.
    It's less possible, but you might have a whole i engine. Does the valve cover have a roundel or "BMW" in big letters?
    cars beep boop
    • mr.vang
      • 4371
      Bet your cluster have been replaced. If the icv is mounted over the valve cover it's an eta.
      • benjamin
        • 174
        It has a roundel on the valve cover. So it looks like somebody swapped out the cluster then? It pulls up to the 6,000 rpm no problem. Am I about to blow it up? Haha
        • mr.vang
          • 4371
          Is there an icv mounted on top of the valve cover?
          • benjamin
            • 174
            If I remember right, there is a bracket with holes through that crosses above the valve cover at an angle, and then the idle control valve is up above that bracket.
            • mr.vang
              • 4371
              That's an eta alright. You might have a chip installed since it is not bouncing off the rev limiter.
              • kronus
                • Apr 2008
                • 13030
                it's also possible that your cluster coding plug wasn't changed to the eta one, so it looks like it's reading 6k when it's actually less.
                cars beep boop
                • benjamin
                  • 174
                  Dang, I thought this thing was all original. How can I tell if my cluster plug coding wasn't changed? I guess having an i tach already is one more reason to do an 885 swap.
                  • Vincer325ei
                    • Mar 2014
                    • 488
                    Need pictures
                    • benjamin
                      • 174
                      I think Kronus might have nailed it. Yesterday after work my boss and I hooked up an old tachacometer of his that connects to the coil. When the tach on my dash read 4,000 RPM, the engine bay tach was reading 3,000. RPM.
