SETA misfire when warm... wtf
  • rickycricketts
    • 806
    So i've done some searching and I cant really find any useful info on this issue.
    Car: 88 325 (seta) 165k auto
    What's happening is the car runs great on cold start until it reaches operating temperature then starts misfiring especially under load. If you hold above 2k with no load it seems to run fine. Misses at idle in neutral and drive (worse). If you shift it manually and slowly creep up the rpms to 3k then punch it, it does not miss. If you floor it in first from 1k to redline the car will misfire>pull>misfire>pull ect. The car runs a lot worse in hot weather.
    so far i have performed the following:
    changed spark plugs and wires (ran a lot better but got worse again)
    new valve cover gasket - (old was leaking and noticed a pool of oil in spark plug holes) - no difference
    changed afm - no difference
    inspected cap/rotor - looks brand new and better than the used good one i was going to put on there
    new coolant temp sensor - no difference
    changed ecu - no difference
    unplugged O2 censor - no difference
    I checked all the boots and connections from the intake manifold forward and everything is sealed there should be no vacuum leaks. vacuum hose on the valve cover is properly sealed.
    I'm now lead to believe this is some sort of fuel issue. Is it possible the cold start injector is stuck open? there is no injector on the other side of the manifold like older etas. I'm about to light this one year only bastard child on fire and let it burn! That's one way to fix the problem ;)
  • BMWManiac
    • Dec 2010
    • 1091
    Do you have the inline fuel pump and one in your tank? Fuel pressure regulator? It does sound like you have an issue with fuel pressure.
    1997 Artic Silver M3
    CES GT4094r 651hp/615tq @ 24 psi
    • rickycricketts
      • 806
      I don't see an inline fuel pump.
      But today I changed the fpr, fuel filter and ignition coil. Still misses. Compression is 175-180 accross the board. Kill it with fire?
      • rickycricketts
        • 806
        Originally posted by 88BlackS-ETA
        What spark plugs did you use? I put in some form autozone and my seta couldn't hold a idle.. So I put in NGK and it runs great.
        ngk v-power zgr5a. I've heard they're the only recommended plugs besides bosch
        • G-Man the Visionary
          • Apr 2013
          • 543
          I'm thinking bmwmaniac is on to something... Have you solved the problem yet? My m30 is doing the exact same thing. When messing with fuel lines shortly after the swap, the return line was dry as if the regulator hadn't been working. Also, been wondering about this cold start extra fuel thing I've been reading about.
          Streetable poly mounts, trans mounts are here!
          http://www.r3vlimited.com/board/show...ght=streetable
          '94 318i
          '07 335i
          '11 X5
          '89 325ic m30b35
            • Apr 2013
            • 543
            Ya, try the fpr... Just did mine, way better... Think the plugs are too fouled to be completely solved. In a few days we'll see if they get any better or if they just need replaced... Again...
            '94 318i
            '07 335i
            '11 X5
            '89 325ic m30b35
            • BMWManiac
              • Dec 2010
              • 1091
              If the plugs are fouled, they are fouled and should be replaced.....make life easier on yourself. Or you can try cleaning them, but at $2/pop, I'd just replace them
              • rickycricketts
                • 806
                Thanks for the suggestion guys. I swapped the fpr from my bronzit and it did not change the way it ran. I'll pull the plugs this weekend and see if they look fouled or leaned. Also going to test the fuel pressure. It should be around 40 lbs right?
                • Mr. Tasty
                  • Jul 2011
                  • 3421
                  3.0 bar, so 43.51 psi
                  2014 Alpine White 335i MSport
                  (Daily Driver)
                  Full Mperformance Aero
                  KW V2 Coilovers
                  VRSF Catless Downpipes
                    • Apr 2013
                    • 543
                    I don't wanna keep throwing random things out there, and it could just be in my head, but when I put dielectric grease on all my temp sensor connections things seemed to get a little better yet. New plugs had to be ordered to the store and should have them today, then we'll see if it goes south again.
                    '94 318i
                    '07 335i
                    '11 X5
                    '89 325ic m30b35
                      • Apr 2013
                      • 543
                      Any luck?
                      '94 318i
                      '07 335i
                      '11 X5
                      '89 325ic m30b35
                      • 3vilE30
                        • Jan 2013
                        • 344
                        Some plugs don't come gapped properly. The single-four-pack NGK ones come gapped, but the individual single pack ones need to be gapped or else you'll have a nasty miss.
                        • rickycricketts
                          • 806
                          Sorry for not getting back to you guys. It's my girlfriends car and I haven't had the chance to work on it again until yesterday. So I have the hood open while it's running and I'm dousing the engine in brake cleaner looking for vacuum leaks and I hear this tick every time it's missfiring. Turns out the tick was coming from the distributor cap. I checked it before and the points looked as good as new but I took it off again to find a little pin hole on the outside where the spark was jumping to one of the mounting bolts. Changed the cap and it runs like a champ. Looks like I need to pay more attention to detail next time.
                            • Apr 2013
                            • 543
                            Nice! I may have to tackle that soon then... Thanks!
                            '94 318i
                            '07 335i
                            '11 X5
                            '89 325ic m30b35
                              • Apr 2013
                              • 543
                              Bosch or Bremi?
                              '94 318i
                              '07 335i
                              '11 X5
                              '89 325ic m30b35
