Anybody know whats up with my pistons?
  • pbsun
    • Jul 2011
    • 97
    Doing an engine rebuild on an m20 that I just bought and found dings on the pistons, anybody have experience with this? If so do you know the cause? Also what did you end up doing; keep them or get new ones?
    Edit: These dings occur on 5 of the 6 pistons in more or less the same spot on each one.
    Thanks.
  • LJ851
    • 7918
    Looks like some debris got into the combustion chamber(s) and dented the piston. Are there corresponding marks on the head?
    I would file the high spots off and smooth any remaining sharp edges, they will be fine to reuse if otherwise in spec.
    Lorin
    The M30 is God's engine.
    • EyExR
      • Jan 2011
      • 959
      detonation?
      M20, okay. But what type of setup is this from?
      My 325iX DIY Threads:
      Front Wheel Bearing Replacement
      325iX Rear Subframe Bushings and MUCH more w/pics!
      325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
      • ak-
        • 12422
        Originally posted by EyExR
        detonation?
        I think detonation would have scattered dimples all over the top of the piston rather.
        1991 325iS turbo
        • whodwho
          • Jun 2008
          • 1547
          This, and look for any embedded metal that could dislodge and continue the journey.
          Agree with this as well, would look like a really bad sand blast job 8^)
          My M20 Frankenbuild(s)
          4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
          • pbsun
            • Jul 2011
            • 97
            EyExR this is from a stock m20b25.
            Thanks LJ851 and whodwho my fear was that I'd have to replace them but it sounds like they will be fine if I shave down the rough area. So the remaining question is what could get into each of them to do damage to this specific section of the piston?
            Here are pics of the head, looks like it has dings on it as well.
            • Cabriolet
              • 9620
              this is very very common. out of the 10 m20s I've rebuilt 9 of them have had this. it's from carbon building up and then banging around. dont worry about it at all.
              Much wow
              I hate 4 doors
              • pbsun
                • Jul 2011
                • 97
                So your saying it would have been a thick layer of carbon build up causing the piston to hit the head?
                Just to make sure I've covered all bases here, any reason this could have caused issues in other parts of the engine?
                BTW, thanks for all the replies.
                  • 37829
                  You could smooth out those spots and run them without issue.
                  Or you could always buy another set of used pistons. They're pretty cheap usually.
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • z122643
                    • Aug 2011
                    • 286
                    You've got the engine apart, I'd do a light hone and new pistons.
                    [/SIGPIC]"we are so totally screwed!"
