Hi all,
I just installed the following upgrade - took me a while but I am glad it all done:
- MarkD chip for 19lb injectos
- weber fuel pump
- 19lb injectors
- Bavarian variable fpr
- M30 AFM
- CAI
Now that the installation is done, I want to know what should I do to make sure things are working correctly. I have read post about adjusting FPR and AFM, and I have also read post about how to use some O2 sensor to analyze the exhaust gas. However, the information are shattered around and sometimes the arguments are contradicting (I guess it's because everyone's upgrade path is different).
So I wonder, for the upgrades that I did, what is the correct way to make sure my air fuel ratio is correct and what adjust should I make to correct the ratio if it is wrong now. (I wish I can get an exhaust gas analyzer but it's costly.) Thanks!
Matthew
- weber fuel pump
- 19lb injectors
- M30 AFM
- CAI
Matthew
