Motor rebuild almost done
  • Lets_dudas
    • Dec 2013
    • 18
    Hey guys,
    I am bolting back together my m20 after a full rebuild and I have run into a snag. I pulled the motor apart to replace the rings and bearings and seals and bolted it all back together. Now I'm trying to set the timing and I can't get the crank to make a full rotation and go to top dead center. I have rebuilt many be and audi engines and have never run into this problem. The head was just machined and everything is new up there. I'm wondering if I should've put the engine at TDC before I put the head on. If this is true I have to unbolt the head and replace them and the gasket which sucks but it's not the end of the world. Can anyone help me out?
  • whodwho
    • Jun 2008
    • 1547
    Yes normally you would put them both #1 TDC first.
    Turn the crank slowly until it hits back it off some(~1/4 turn) and then turn the cam slowly and dont let it snap around from the springs, it is easy to bend the valves.
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • my_bmw_sucks
      • Feb 2014
      • 16
      Pistons are contacting valves. Ideally you should have put both timing marks to TDC and then backed off the crank so the pistons went down in their bore a bit to avoid valve contact when installing the head. Then you could bolt up the head and time the car.
      Not sure if this will work but it's worth a try. I'd take the valve cover off to see which valves are in the down position. Back off the crank so there's no contact, then rotate the cam a bit so the valves in the down position pull up, and then try rotating the crank again. Keep working at it until you get the timing marks into position. A pain in the ass but could save you the cost of a new head gasket and bolts.
      *looks like whodwho beat me to it
