Hello!
just finished my 2.7 m20 build and i'm having a few problems.
first problem:
When the car is running at idle and you quickly open the throttle the Rpms drop and the car wants to stall.
If you open the throttle slowly this problem doesnt occur and the car revs as it should.
second problem:
When driving the car it won't rev past 4000 Rpm and it feels like a revlimiter is cutting in. this happens in every gear.. You can keep pushing it and it will go beyond 4000 rpm but it just doenst give any power. You can hear this in the video i made.
Any suggestions what could cause this?
setup:
- 2.7 Seta block
- 325i head with catcams camshaft
- 19Lb ford injectors
- full 325i intake and exhaust
- New parts: fuelpump, fuel filter, distributor cap, Rotor, blue temp sensor
- tried another ICV and AFM
first problem:
second problem:
setup:
- 2.7 Seta block
