Weird oil leak ofter oil, pan, and filter change? M20
  • Sieve
    • Nov 2013
    • 34
    Please feel free to watch my YouTube video below and give me some guidance on what to do! So there is an oil leak dripping down just below the oil filter from some kind of openeing? There is no lose hoses. Only leaks while car is running. Just finished doing the pita pan job, noticed a new leak! Any help is appreciated! Thanks!
    BMW M20 Oil leak: http://youtu.be/bbdqTQaduBw
  • Chessmaster
    • Jun 2012
    • 501
    Seems like the oil cooler base.
    • Sieve
      • Nov 2013
      • 34
      ? Some more info please? How can I stop the leak, and is there something missing where it's leaking from.
      • dnguyen1963
        • Nov 2011
        • 2651
        Is that oil spitting out? you'll need to remove the c-clamp and change the o-ring.
        • Sieve
          • Nov 2013
          • 34
          Yup that's oil, there is a c clamp and oil ring right there? Like where it was dripping from.
            • 37833
            If it were me I'd pull off the oil filter housing and replace all of its seals.
            Here's everything you need: (BMW part numbers)
            11429059338
            11421714764
            11421265670
            17222245358 x2
            Grover Beach, California
            BimmerHeads.com
            • Sieve
              • Nov 2013
              • 34
              Ok great, the oil light above the rear view is for temp right? I've had it come on a few times. I wonder if the leaking is related to the oil cooler and lines also
                • 37833
                The oil light in the check panel is for oil level.
                BimmerHeads.com
                • Sieve
                  • Nov 2013
                  • 34
                  Ok, so it looks like some oil filter housing gaskets will aid the issue, Thanks! I appreciate the feedback
