325e randomly won't start, changed almost all the sensors
  • ferrarix99
    • Jan 2011
    • 39
    Hello guys,
    I have a slightly tricky issue that I'm dealing with. My 87 325e will randomly not start. It's a motronic 1.0. Some background info:
    Happens when the car sits longer than a day. If I drive the car every day it starts no problem.
    Appears to be related to temperature/humidity.
    Changed the crank sensor, all coolant temp sensors, cap, rotor, sparkplugs, wires, hp fuel pump, 3 main relays in that separate box.
    Noticed that when its having its little fit the hp fuel pump is not kicking on which leads me to believe it's an electrical issue somewhere up the line telling it not to kick on.
    Any input you guys may have would be very helpful! Thank you!
    1987 325e - Daily Beater
    2005 M3 Vert
    Want your car coded in the NY/NJ area? PM me.
  • Andy.B
    • Sep 2011
    • 1650
    Crack open the dme and check for corrosion inside. You might have a failed/failing dme.
    • ferrarix99
      • Jan 2011
      • 39
      I will definitely give it a look over. I have been looking into ecu doctors and their rebuilding service. Any recommendations to get a rebuilt dme?
      2005 M3 Vert
      • Andy.B
        • Sep 2011
        • 1650
        For an eta, I absolutely wouldn't bother. There are enough people ditching the motronic 1.0 for 1.1/1.3 that you can buy a whole stack of used 027 dme's for the price of one reman unit. I had one fail due to corrosion, and unfortunately just sold my good one (with a chip) for about $30 shipped. Hit up the classifieds and snag a used one if you need one.
        • 603Racing
          • Dec 2010
          • 612
          Check for power coming to the fuel pump relay when it does it. Sounds like it could be a short, wiring or ECU as previously mentioned.
          90 325i DD/Track
          03 Durango 5.9
          Originally posted by e30mpg
          It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
          • jprastrullo
            • Jul 2012
            • 169
            this might sound dumb, but have you replaced your starter?
            My '87 Alpinweiß 325is Build Thread | Parts FS | Parts Wanted | Feedback
            • ferrarix99
              • Jan 2011
              • 39
              From what I've read converting to 1.1 or 1.3 is kind of a pita and I'd prefer just to swap it out as opposed to swapping sensors and redoing wiring. Thank you for the suggestion though. If there is some kind of newer method that is easier I would be open to that but from what I've read it appears to be somewhat involved.
              Sorry, forgot to mention.. Starter is new and car cranks all the time, never had an issue with it not turning over.
              2005 M3 Vert
