Hi everyone
Greetings from Portugal!
I need some help figuring out how to fix the odd idle problem on my 85 320i.
First i can´t find anywhere a clear reference to my engine. I think it is a LE-Jetronic but every forum or site i read about it talks about an Idle Control Valve which i don´t have. It has chrome bumpers though...;D
From what i can see there is an auxiliary slide valve that i took off and tested and it slides according to temperature just fine.
So, now the problem... on cold start the engine revs up to 1500 for a few seconds and the drops almost to stall, then the vacuum valve near the throttle revs it up and it stays on 1500 a few more seconds and drops again...on and on until the engine warms up. Then the idle is fine.
Vacuum leak? there´s a ton of vacuum hoses around...
I´ve played with everything i could from the AFM to the idle stabilizer valve (above the valve cover) to the vacuum valve but couldn´t figure out any combination that worked.
My engine is basically this one:
But the 320i one.
Thanks for any help and best regards
But the 320i one.
