I just replaced 2 fuel lines, the intake manifold gaskets, a few hoses and throttle body gasket. Here is a link to the sound http://youtu.be/BibQ6th7w2Y
Engine Stutter
Check for vacuum leaks. The easiest way is to take a can of crab cleaner or brake parts cleaner and spray it on every hose you touched or didn't touch in the engine bay that has anything to do with vacuum or incoming air besides the main intake and air box. The idle will change quite a bit if there is a leak present there. The best way is too do a smoke test, search YouTube for home made smoke test for vacuum. You prob just have a vacuum leak, make sure you spray around the base of the intake to make sure your new intake gasket isn't leaking. And also check at the base of the throttle body as well.sigpic87 325E The Honey Badger
