No heat
  • oxymoron
    • Nov 2011
    • 356
    No heat
    I deleted the lines to the heated throttle body, mostly because it was causing two leaks. Now that its winter im finding that my heat blows ice cold. The temp guage is right where it should be. But both hoses to the heater core feel luke warm with no pressure. I assume if my heater core was clogged it would be very hot on one side and cold on the other. Does anybody have similar experience with this or insight as to why my heater core isnt getting any pressure ? The rad hoses are hot and have pressure and I dont understand how that could be working but not the heat
  • glnr13
    • 1334
    is your heater control valve working? turn the ignition to on, listen closely and turn the temp to hot, you should hear a soft clunk or click.
    • oxymoron
      • Nov 2011
      • 356
      Ok I flushed my heater core with compressed air and bled the coolant and its all good now
