Hi all,
I just picked up a 1991 325i vert w/ 100K miles. Excited to make it my own. Engine bay has some oil leaking from somewhere but otherwise runs pretty smooth. Figured I'd just use the cold winter to fix it all up and take care of the head gasket / timing belt, etc. While I'm in there I plan to do the following below. Am I missing anything you'd all do?
Goetze Headgasket
Headgasket Set
Head Bolt Set
gasket sealant
Timing Belt
Timing Belt Tension Pulley (do I need this for a 1991?)
Water Pump - Saleri
Oil / Filter change
Bav Auto Tune-up Kit (distributor cap, ignition rotor, sparkplugs, air filter & fuel filter)
Fan Clutch & Wrench
Belts (AC, alternator, Pwr S.)
Car fax states the thermostat was replaced at 90K miles (has 100K now) but that was back in 2007. Would age or mileage cause that to go? I was hoping it was still fine.
Thanks for your help,
Andrew
Goetze Headgasket
Headgasket Set
Head Bolt Set
gasket sealant
Timing Belt
Water Pump - Saleri
Oil / Filter change
Fan Clutch & Wrench
Andrew
