Hello all,
I am the new owner of a 1987 BMW 325i (Build Month 01/87), with the intent of turning it into a rally car for Stage Rally.
My current issue is that I recently have repaired many things on the car, but now it will not start, this is the order things have happened:
Purchased car
Had Rough Idle
-Ran Top Engine Cleaner, ran much better
Adjusted Valve Lash
Replaced the following
-Timing belt
-Water Pump
-Tensioner
-Distributor Cap and Rotor
-Spark Plugs (They are Platinum, but I now know Copper is a better choice correct?)
-Oil Change
So before and after all of this, the car started and ran fine for several startups. Then one day I go to start it and nothing happens. now it should be noted, that when it was running, it was only for a few minutes, but had no coolant, and no air filter attached in front of the AFM. Also, every time I ran it, I disconnected the battery after running it to make sure the battery did not die. From what I have read, the DME is fairly easy to blow. The Injectors are firing (I think, it smells of fuel when I remove spark plug). However, grounding a spark plug, there is no visible spark.
My Question specifically:
How can I prove out the DME as being good/bad. In-line fuse in trunk near battery is OK. Also, if the DME is bad, I have read the 173 is better? (do not know how to differentiate between DMEs)
P.S. new to old BMW's so please try to explain various Acronyms, I have been a Mechanic for 6 years, but I am new to old BMW's. Before this I had a 1967 Ford Mustang.
Purchased car
Had Rough Idle
Adjusted Valve Lash
-Timing belt
-Water Pump
-Tensioner
-Oil Change
