M20B25 / It just stopped running!
  • KMOSES
    • 591
    I was coming home from 1 1/2 hr. drive Friday when out of the blue my '87 325 (M20B25) acted like the the ignition switch was turned off, it just stopped running. I pulled over, and tried to restart it, it would crank but not start. After getting the car home, I checked in the following order:
    Cam was turning when cranked (OK),
    Main Relay (OK),
    Fuel pump pressure (OK),
    Spark (No Spark),
    Spark from primary coil wire (No Spark),
    Power getting to coil (OK),
    CPS (OK),
    Pulled the ECU connector and checked the Power, Grounds and all other values (All OK),
    Replaced the ECU, it tried to crank on the first try, got it started, took it for a drive. Hooked up the old ECU again, no start.
    When you have fuel but no spark, sometimes it "is" the ECU!
  • DesertBMW
    • Aug 2011
    • 1042
    you used another ECU and the engine runs... so.
    • KMOSES
      • 591
      Look at the threads, CPS, main realy, blown fuse, bad connection, tosted rotor, ect..
      It's never the ECU.... But sometimes it is...so.
      • TRAK WDW
        • Aug 2014
        • 157
        Nice checklist!
        Glad you found the problem, now this will remain for future owners who have this same issue :up:
        Harp
