Weird noises on start-up (Video inside)
    M20 has been making weird noises on start up. It's also been draining the battery when it rains (perfectly charged when dry though). Rainy season is here and I've pretty much needed to jump/bump start my car every morning
    Been getting pretty tired of it
    Obviously something's not right: there is a loud whine on start-up and a metal hissing-scraping coming from the alternator area when cold, but will go away after a drive/when hot
    Any help would be awesome
    It sounds like you just need a new alternator belt.
      Can't be
      Brand new belts
        haha. you need a new starter. sucka.
        that's the starter failing.
        Much wow
        I hate 4 doors
          same noise from mine on cold starts...annoying. I hope to find out through this post what it is exactly
            Found that my no-start issue after a rain might just be a cold start issue that was barely arriving from the battery; luckily it's still in warranty so I can get a new one
              Confirmed
              Had someone start the car while I listened to the engine
              Starter is definitely on it's way out
              No start/battery drain issue was traced to ABS relay wiring. Fixed issue; Car was draining at .5A, but is now draining at .02A which is close to stock power drain.
