In the next month i plan to replace the guibo, CSB, Timing belt and transmission mounts as well as Alternator belt (Just replaced the other 2 a month or so ago.)
So the car is a 1991 325i Convertible, Auto transmission.
I've referenced real OEM for most of the part numbers, besides the Timing belt kit. I mainly want to make sure I'm not gonna get everything torn apart and then realize i forgot to order something. So here's what I got:
Alternator Belt:
https://www.fcpeuro.com/products/bmw...lt-11511706710
CSB:
https://www.fcpeuro.com/products/bmw...in-26121226723
Guibo:
https://www.fcpeuro.com/products/bmw...bo-26111225624
Guibo lock nuts (6):
https://www.fcpeuro.com/products/bmw...ut-07129964672
Trans Mount (2):
https://www.fcpeuro.com/products/bmw...nt-24711128372
Timing Belt Kit Includes:
Timing Belt
Thermostat
Camshaft Seal
Crankshaft Seal
Valve Cover gasket
Rocker Arm shaft end plug
Timing Belt tension
Thermostat
https://www.fcpeuro.com/products/bmw...-325ic-e30kit1
Anything else I'm leaving out?
Thanks
Chad
Alternator Belt:
CSB:
Guibo:
Trans Mount (2):
Timing Belt
Thermostat
Camshaft Seal
Crankshaft Seal
Valve Cover gasket
Timing Belt tension
Thermostat
Thanks
Chad
