86 325e poor mpg
  • RyanD
    • Nov 2014
    • 9
    86 325e poor mpg
    I just picked up this car. Changed the oil and the thermostat and put nrw belts on it. From what i can tell it runs fine bit im getting about 16mpg. 90%of my work commute is freeway.
    Whats going on? The only thing i can think of next is a valve adj and a new o2
  • indecline
    • Sep 2007
    • 244
    Spark plugs and oil change.
    1989 325I(M20B25US)|KAMotors CAI|Bilstein Sports|H&R Sports|ST Sways|SSSquid Tune|Red46 Sump Armor|
    • 101
      • Jul 2011
      • 764
      Agree with replacing the O2 sensor and plugs if you have no history on them. Check the resistance readings for the coolant temperature sensor for the ECU to make sure that sensor is within spec. Is the air filter clean? Does is smell as if its running rich?
      Could the rear diff have been changed at some point? Eta should have a 2.79 or 2.93 ratio for the manual transmissions.
      Check for sticking calipers or e-brake. Even a small drag can be significant.
      Something is up for sure. My manual eta with a 200K mile motor gets > 30mpg on the highway.
      101
      The E30 collection:
      1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
      1987 325is - Delphin / Black Sport (son #3's)
      1987 325i Convertible - Triple Black
      1989 325iX Coupe - Diamondschwarz / Black Comfort
      1990 325iX Coupe - Sterling Silver / Grey Sport
      1981 Fiat 124 Spider 2000 - Green / Tan
      1998 Volvo V70 GLT - White / Tan
      1998 Volvo S70 T5 manual - White / Taupe
      2001 Ford Windstar - Silver / Grey (parts hauler)
      2006 Lexus GX470 - White / Tan (tow rig)
      • RyanD
        • Nov 2014
        • 9
        I will do that thanks.
          • 37833
          Agreed on plugs and o2. I also recommend the valve adjustment and a new cap/rotor.
          Otherwise checking the ECU temp sender as well as TPS adjustment is a great idea.
          If the intake boot or vacuum lines are cracked replace those as well.
          Grover Beach, California
          BimmerHeads.com
