Recently had some parts installed on my car, new intanke mainfold, m50 injectors, and valves adjusted. everything was running great until i disconnected the battery to install a new coolant senor. connectned the battery and the car started up fine no problem. let it run for 5 mins or so and turned it off. couple days later went outside to go to school and the car would not start. cranked and cranked. and nothing. replaced the 3 main relays, and it feels like it WANTS to start but doesnt. i found out if i disconnet the negative battery cable and then reinstall it the car will fire up right away. ive even drove it around the block a few times. and it runs great, voltage reads 14.0-14.2 when driving. when it doesnt start it reads 11.7-12.0. i put in a new coil and im going to get a new battery tomorrow as well but just cant figure this out at all
Starting problem
How much confidence do you have in the M50 injectors you installed? Were they new or used? When you disconnect the battery cable it resets the DME to the default engine mapping. As the car runs this mapping adjusts to match your particular engine conditions and environment (adaptive mapping). It could be that the new injectors are causing issues with the mapping. I understand that the re-mapping takes some amount time so it may not be what's happening in your case. Worth a shot to reinstall the old injectors and see what happens.
DME has been swapped. I had the m50 injectors running in my car for about 2 weeks prior to me replacing the coolant temp sensor and the car ran fine. Ever since the sensor was replaced have had problem. Even bought another new sensor to make sure it wasn't that. Totally stumped by this. Replacing the fuel pump tomorrow and I'll report back to see if that's the issue
Originally posted by vpilarrt View PostIs this on the 84 318i? Which of the 3 temp sensors did you replace? Did you get all the harnesses plugged back into the correct sensor?
I also replaced the battery this weekend and nothing changed at all. stumped on what it could be, drove it all day yesterday as well and the car runs great and pulls good. one thing i noticed is my windows now take fever to roll up and my volt meter will go from 13.8 with light and radio on down to 12.9 when trying to roll up the window.
here is a update with videos guys and what I'm talking about, first video is with the car sitting overnight from the last time i started it.
this video is when i disconnet the negative battery cable for 5 seconds or so and re connect it the car fires up no problem.
