intake advice
  • isaiahliepold
    • Nov 2014
    • 5
    intake advice
    I am wanting to run a cold air intake through one of my headlamps, but how do i not take on water?
    like this...
  • efficient
    • Feb 2012
    • 3312
    Use stock box with a hose and connect the hose to the headlight.
    • isaiahliepold
      • Nov 2014
      • 5
      I am going to use this intake, but i live in indiana and it is a daily driver so i am afraid of water draining in.
      http://www.ebay.com/itm/NEW-Ver-5-BM...95e1bc&vxp=mtr
        • 37833
        If you're worried about water coming in, don't put your intake in your headlight... Simple.
        Grover Beach, California
        BimmerHeads.com
        • isaiahliepold
          • Nov 2014
          • 5
          how can you stop water drainage, angle it up and a small drain hole? but if i wo that will it still suck it in?
          • dnguyen1963
            • Nov 2011
            • 2651
            Most air filters have been treated with oil to prevent water from entering the intake; however, if you have your hose where the headlight is then you will be sucking in a lot of water. I don't think any filter can handle that much water.
            • Cabriolet
              • 9620
              use your stock airbox.
              Anything else will be a loss of Horse Power.
              Much wow
              I hate 4 doors
              • Bullhead
                • Sep 2014
                • 532
                The setup your wanting to do is usually a "race" only setup. Most of those guys never drive in the rain or if they do it's not very much. There will be no way to stop water from coming in completely unless a deflector of some kind is used. But then you will lose the "ram" air feature of the design.
                sigpic87 325E The Honey Badger
                • Old city bimmer
                  • Jun 2014
                  • 1114
                  This application is usually race only. But if you are doing it for aesthetics then use the stock box like mentioned.
                  323i MTEC1
                  Z3 coupe
                  E60 M5
                  • siffer
                    • 91
                    Waste of time. Been there and went back to stick box and drop in filter.
                    • Bullhead
                      • Sep 2014
                      • 532
                      If your dead set on it you can fab up a perforated cover for it that you can place on the outside when it rains (like KC uses for their lights) it would have to be slit down so water couldn't readily pass through but air could. But if you ever forgot to put it on 1 day then you will have an engine full of water :(
                      • Jaxx_
                        • Dec 2009
                        • 1880
                        Okay, I'll bite... Unless you manage to drive through a monsoon I don't think water in the intake will cause any motor damage. Perhaps it'll damage your AFM, but that's probably about the extent of issues you could case with some water on your air filter.
                        With that said, in almost all applications, cone filter intakes result in a loss of horsepower.
                        • estoguy
                          • May 2013
                          • 1087
                          Stick with the stock box - it's already a CAI. Doubt you'll do much better with any other setup.
                          Estoguy
                          • djmossm42
                            • Jul 2012
                            • 687
                            Agree just replace the stock snorkel with a longer 3 in. Tube and velocity stack. keep the stock box and use a drop in filter
                            Wheelwell
                            Shadowline Motorsport: LED & 3D Printed Accessories - 10% off for new customers!
                            LED Bulb Thread
                            R6 LED Review
                            • ngampleh
                              • Jul 2012
                              • 466
                              I dont have any problem with water.. Even on heavy rain at tropical country...
                              [ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
                              [ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
                              Transaction Feedback
