I have a question. I did a tune up and adjusted the valves. I think I messed up because my motor is ticking more the did. I used the feeler gauge .025 isnt that right?
valve adjustment
Tags: None
Are you aware that there is spec for a cold vs warm engines? I'd let the engine cool down and try again tomorrow. My first time I did my valves I had to do it twice to really get them dialed in.
Honestly, its pretty picky where it needs to be when you're talking about .01 differences. So I'd go through and measure again. Verify that the nuts are nice and tight. You'll eventually get it all nice and dialed in.
Also, hopefully you're using feeler gauges with a foot on them- the straight ones are hard to measure on the M20.
GL!Last edited by Klug; 01-16-2015, 08:24 PM.555Garage - Kingston, PA
'13 BMW e70 X5 35d
'95 BMW e34 525i
'92 BMW e30 325i S52 Vert (Quade the Vert)
'92 Range Rover Classic
'90 Range Rover Classic
'89 BMW e30 325i Coupe (The DIRTY30)
'81 VW MK1 Rabbit Caddy Diesel
'76 Honda CB550K Cafe/Brat
'67 Pontiac LeMans
'24 Model T Depot Hack
....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
FYI, I prefer to adjust them while the engine is cold.
As according to the bible (Bentley)
Engine Hot: 4cyl .25mm / 6cyl .30mm
Engine Cold: 4cyl .20mm/ 6cyl .25mm555Garage - Kingston, PA
'13 BMW e70 X5 35d
'95 BMW e34 525i
'67 Pontiac LeMans
i think i tighted them too tight damn my feeler gauge says .025/.36mm. will it break my motor i have a 400 mile trip tomorrow i can readjust on sunday.Comment
I think on your feeler gauges that first number is in inches. Your adjusting them way too big.
Here's the metric and SAE readings.
Engine Hot: 4cyl .25mm(0.010 in) / 6cyl .30mm(0.012 in)
Engine Cold: 4cyl .20mm(0.008 in)/ 6cyl .25mm(0.010 in)
Remember- never use inches or SAE measurements on anything dealing the e30. Metric all day every day. The way BMW designed things the way to be. Throw out your SAE tools.555Garage - Kingston, PA
'13 BMW e70 X5 35d
'95 BMW e34 525i
'67 Pontiac LeMans
I have no idea the condition of your e30- couldn't tell ya. If you don't hear any ticking and the valve adjustment is good- you'll be alright.
However- 400 miles...have you changed your timing belt and wheel bearings?555Garage - Kingston, PA
'13 BMW e70 X5 35d
'95 BMW e34 525i
'67 Pontiac LeMans
those real replaced prolly 30k miles ago. im proud to say my e30 is in good shape needs shocks but mechanically goodComment
Your worried about wheel bearings? I'm pretty sure I have driven 400 mile plus with a crapped out wheel bearing,it was just loud as hell
But op you should be fine 400 is nothing to worry about and first time I adjusted my valves I did the same thing(inches instead of mm) just do it again the proper way and you will be goodComment
I've driven 10,000 miles on a roaring rear wheel bearing.
Iiiiiiiregardless, I would readjust them properly before the road trip. I've snapped rockers from having to much gap. It'll delay you an hour, but changing out broken rockers is a much bigger whore than adjusting valves.
And if it says .025mm, you made them way too tight. That feeler would be about the thickness of aluminum foil. I don't think you did this.
Also keep in mind that the tops of your valves may be "dished" a bit and the feeler gauge may be bridging the dished part and you could be making the gap too wide (louder tapping). That's why on older motors, you place the feeler between the cam and the rocker foot instead of between the eccentric and the valve top, but there is a different measurement for this placement (slightly tighter) because of the rocker ratio.
Also, I assume this is an m20. I think I read that up there somewhere.
Good luck and adjust them before you leave. If you absolutely can't, just keep the revs low/no red-lining.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
