Solved
  • Nick's e30
    • Mar 2012
    • 676
    Solved
    Solved.
    No antenna? I sell plugs!
    Here: https://www.r3vlimited.com/board/sho...77#post4937877
  • dnguyen1963
    • Nov 2011
    • 2651
    Remove the spark plugs to see if you have excess fuel. It sounds like your engine is getting too much fuel.
    • dnguyen1963
      • Nov 2011
      • 2651
      Yes, they will be wet with fuel.
      • jalopi
        • 2370
        do you have a friend with a wideband that'll let you use it for a bit? i've always found reading spark plugs to be a bit of a crapshoot
        • jalopi
          • 2370
          did you try swapping the ICV over? never hurts to try
          • jalopi
            • 2370
            i've seen ICVs before (not m20 ones, but other stuff, like on hondas) get jammed up with carbon and shit. might wanna try squirting some carb cleaner in there and let it sit for a few hours, then try firing it back up
            • dnguyen1963
              • Nov 2011
              • 2651
              When was the last time you changed the O2 sensor? You can clean the spark plugs with sand paper, re-gap, then try to start the car while you wait for the new plugs. That's a lot of carbon deposit on the plugs.
              • jalopi
                • 2370
                if it was running like ass off idle i could see the tps being an issue, but considering you didn't mention that can i assume it runs fine off idle? probably not the tps.
                how's the fuel pressure regulator? i doubt that's it but they can cause engines to run rich if they're not bypassing enough pressure, something that happens once they get enough age on em
                • LateFan
                  • May 2013
                  • 4436
                  Jim Levie says:
                  (search for advice from jlevie)
                  The first thing to to is to start at the top of what follows and work to the bottom without skipping and steps. More times than not you will find the problems, fix them, and be a lot happier with the engine/car.
                  Idle or hard starting problems are most commonly caused by intake leaks and/or
                  a sticky or defective Idle Control Valve (ICV). The only reliable method of
                  locating intake leaks is to have a smoke test run on the intake and crank case
                  and to test the brake booster with a gage and vacuum pump. The complete list
                  of possible causes of an intake leak is:
                  Intake boot
                  Throttle body gasket
                  ICV hoses & connections
                  Brake booster, hoses, and connections
                  Crank case breather hose
                  Evaporative control hoses, valve, and expansion tank
                  Fuel pressure regulator & hose
                  Injector seals
                  Valve cover gaskets & bungs
                  Oil filler cap
                  Dip stick o-rings
                  Oil return tube o-rings
                  Pan gasket or oil level sensor gasket
                  While leaks in some of those can be found by inspection or by spraying carb
                  cleaner on suspect areas, not finding leaks that way doesn't eliminate the
                  possibility. Only a smoke test will really work.
                  Once the possibility of intake leaks is eliminated, the ICV needs to be
                  removed and cleaned with carb cleaner until the vane inside moves freely. When
                  the ignition is switched on you should be able to feel vibration from the
                  ICV. If no vibration the ICV is bad, there's a problem with its wiring or
                  connector, there's a problem with the TPS, or the DME (or Idle Control Module
                  (ICM) on an ETA car) is faulty.
                  For the DME (or ICM) to control idle, the idle switch in the TPS must work
                  correctly. The switch should close when the throttle stop is 0.030-0.060" off
                  the idle stop screw. Hearing a click doesn't mean the TPS is working. Check
                  with a meter or test light.
                  The fuel system should be tested via the suite of tests in the Bentley manual
                  as invalid rail pressure can be a contributor to idle and starting problems. A
                  simple injector check is to pull the injectors, jumper the fuel relay to run
                  the pump, and see if the injectors are leaking. You can also point the
                  injectors into a towel, remove the coil wire, and crank the engine to see if
                  all of the injectors appear to be spraying in a similar fashion. The best
                  approach to possible injector problems is to have the injectors cleaned and
                  flow tested. Since raw fuel can or will be released in these tests, have a
                  fire extinguisher handy.
                  While a bad check valve in the high pressure pump can result in longer than
                  normal cranking, if the fuel system is working as it is supposed to the rail
                  will reach normal pressure in a few turns of the engine. A weak pump, clogged
                  filter or leaking FPR in conjunction with a failed check valve can result in
                  longer cranking and/or idle poroblems.
                  The O2 sensor can be a contributor to idle problems. The O2 sensor is a
                  scheduled maintenance item with a useful life of no more than 100k. If the
                  sensor has that mileage or more (or is of unknown age), replace it.
                  The AFM can be a contributor. If the vane doesn't move freely or the
                  resistance track is worn the DME may be receiving invalid data from the
                  AFM. And if someone has fiddled with the bypass air adjustment the DME may be
                  unable to stabilize idle. The bypass air adjustment should only be adjusted
                  per the procedure in the Bentley and with an exhaust gas analyzer. And even
                  then everything else associated with engine management has to first be
                  operating properly. If the AFM becomes a suspect, replacement with a good used
                  unit is the best approach.
                  Improperly adjusted or malfunctioning valves will affect idle and starting. As
                  can compression issues from ring or cylinder wear. A valve adjustment is
                  called for every 15k. A useful diagnostic is to run compression (dry and wet)
                  and leak down tests on the engine. Aged ignition wires, plugs, distributor
                  cap, or rotor can cause problems. Insulation does break down with time and
                  heat. And since the youngest E30 is going on 20 years old, if the ignition
                  system is original or the plugs are old replacement is indicated.
                  Although not usually a problem, a bad DME temp sensor is a possibility. That
                  generally won't cause an unstable idle, but can cause hard cold or hard hot
                  starts and/or a rough idle. As can problems with the timing reference
                  sensors. Although not commonly encountered, a bad harmonic balancer on an
                  M20B25 or M30 engine will cause problems.
                  When all other possibilities have been eliminated and idle or starting
                  problems persist, replacement of the DME, or if applicable the ICM, is
                  indicated.
                  In many cases the cause of problems will be a combination of factors. So it is
                  important to test and repair all of the possible causes.
                  __________________
                  NASA & BMWCCA Certified Instructor
                  NASA MidSouth Spec E30 Series Director
                  • LateFan
                    • May 2013
                    • 4436
                    Our 86 ES died every time after maybe 10 minutes - drove us crazy. It was a combination of air leaks, a bad idle control valve, changing the TPS, changing the fuel pressure regulator, rebuilding the AFM and injectors, and finally swapping in a known good used ECU. Most reliable car in the house now.
                    • LateFan
                      • May 2013
                      • 4436
                      Originally posted by Nick's e30
                      One thing at a time though. ETA for arrival on the plugs is Thursday.
                      Yep. If too many variables, start with the most likely and/or cheapest things, eliminate those, and work your way up. We never would have swapped the ECU, but that was the last possibility.
                      • jalopi
                        • 2370
                        good to hear. try soaking the non-electrical bits of the ICV in carb cleaner or something like that; might free up any gunk in there and you'll have a spare
