Hi everyone!
I purchased an E30 a couple months ago. When I bought the car, it overheated because of failed water pump. Once I changed the water pump out, the started to spew white smoke out of the exhaust indicating that that there was a leak in the head gasket, and coolant was getting into the combustion chamber. Therefore, I ordered a new head gasket and replaced it. Once I finally put everything back together, my engine wouldn't start. The starter turns the engine over, and fuel is getting into the combustion chamber. Also, the spark plugs do spark when I took them out and placed them on the valve cover to test them.
Before I changed the head gasket, the car started and ran. Now I have no idea what to do or what the problem is. I'm thinking maybe it has to do with the injectors or some kind of electrical wiring, but fuel is reaching the combustion chamber. Any help would be greatly appreciated!
