Weird vibration under throttle
  • HennaE30
    • Apr 2014
    • 1965
    There is a weird vibration under 1/2 throttle or more. Mostly noticeable in 3rd 4th and 5th between 2000-3000rpm.
    i was thinking maybe it is an exhaust leak, because its a horrendous drone/vibration. But i thought id post it in here because its more encompassing.
    Any ideas on what it might be?
    84 325e btw
    edit: it also just had motor tranny mounts done in December if that helps at all.
    Originally posted by flyboyx
    how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
    Originally posted by Northern
    beer is my new liver cleanse.
    Henna - '84 Hennarot 325e
    Lola - '89 Schwarz 325is - being saved
    Christine - '88 Schwarz 325is - Spec E30 Racecar
    '01 White F150 Lariat 4x4 Supercrew - Daily
    Dad's '05 Interlagosblau M3
  • Helltime
    • Sep 2011
    • 96
    Make sure all of your drive shaft bolts are still there. Ever looked at the guibo to make sure its not worn?
    1990 325i 5spd
    09 135i 6spd m-sport package
    • HennaE30
      • Apr 2014
      • 1965
      Guibo was changed in May, less than 3k on it but wouldn't that be speed related? Not load/rpm related? That is why I think it is engine related... It runs great and all, just the vibration under load
      • Helltime
        • Sep 2011
        • 96
        If the bolts were reused you could be missing one. I have been told they should be considered 1 time use.
        It is something you would notice under acceleration, as that would be when it is most likely to flex. I have had 2 different e30s now that have either lost or broken a drive shaft bolt on the transmission side and under acceleration there is noticeable vibration, but at cruising speed there is nothing. First time it happened to me It was after a hard 1-2 shift going onto a county highway and I didn't know anything was wrong until I came to a stop light and went to accelerate. 2nd car was pretty much same situation, drove it a little hard, get off the highway and to the stop light, go to take off and noticed a little vibration, the harder I got on it the more vibration there was, but once at speed nothing (pulled it in the garage, immediately jacked it up, and sure enough lost a drive shaft bolt transmission side).
        1990 325i 5spd
        • HennaE30
          • Apr 2014
          • 1965
          New hardware used on guibo, managed to get the car on jackstands in an attempt to diagnose a transmission leak that I'm having and all the guibo/driveshaft bolts (both tranny and diff sides) are still there and intact.
