Valve Clearances and Temperature
  • turbo55
    • Jul 2014
    • 223
    I started putting in new eccentrics into my M20 last night (I read that old eccentrics will have a dimple wear in the spot where the valve stem makes contact, causing improper clearances) and ran into some questions:
    From the Bentley Manual:
    Over 85 C (hot engine) – 0.012 inches
    Under 35 (“cold” engine) C – 0.010 inches
    I thought, that can’t be right, you’d expect the clearances to shrink when the engine is warmer due to the valve stems growing. However, the manual is right, I last adjusted the clearances in October to 0.010” and yesterday night (-7 C in the garage), I couldn’t fit my 0.010” feeler in there before I loosened the eccentrics to swap in new ones. The only explanation I could think of is that since the head is aluminum and the valve stems are steel, the aluminum would shrink more than the steel (aluminum has almost twice the thermal growth coefficient of steel), effectively making the valve stems longer with respect to the head, making the clearances shrink.
    So then the next question, what do I adjust the clearances to when working on a “very cold” engine. Assuming linearity, you’d expect that if at 85 C the clearance is 0.012”, 35 C the clearance is 0.010”, -5 C the clearance should be 0.008”, right? Anyone else run into this when working on a “very cold” engine?
  • estoguy
    • May 2013
    • 1087
    The key thing is that the engine SHOULD be cold (sitting at least 6 hours) before doing valve clearance. Honestly, it shouldn't make a difference... metal doesn't shrink in the cold like that. Just adjust to 0.010" and call it done!
    Estoguy
    • turbo55
      • Jul 2014
      • 223
      Well, I agree that metal doesn't shrink (or expand for that matter) much, but it does shrink some, that's why there are hot and cold clearances.
      I just did them all last night to 0.009".
      I ended up doing a calculation (assuming an initial height for the head and valve stems of 4.5") to see clearance growth due to the different metals going from 35 C to 85 C and..... I got a result of exactly a 0.002" increase (i.e., 0.010 + 0.002), which is exactly the 0.012" clearance Bentley gives.
      Yesterday's garage temp was -1 C, using the same calculation I got a resulting clearance of 0.0084", so I set them to 0.009" to be safe. I'll probably check it again in the summer when it's not so damn cold out.
