Anyone Running A 284/272 or Similar Cam?
  • Low Level E30
    • 1646
    As mentioned in the title - anyone out there running a 284/272 asymmetrical cam, or similar?
    How do you like it? What is the power delivery like?
    Did you upgrade your valve springs?
    Does it have a lumpy idle (or not idle at all...) ?
    Any further input?
    Thanks!!
  • Low Level E30
    • 1646
    -Bump-
    • MrK
      • Jan 2006
      • 709
      I wouldn't worry about idle. I idle fine (if a little lumpy) at exactly 800rpm.. and I have a 304/304 :D
      This is your M20 on steroids:
      • Low Level E30
        • 1646
        Oh, I'm not afraid of a lumpy idle :D --- I like that!
        I am really more interested in what I need to run the cam --- adjustable cam gear? New or upgraded valve springs? Etc.
        And how does it perform? Where does the power come in? Does it have an on / off switch at a certain RPM?
        • yozsi
          • Feb 2006
          • 337
          if your talking about the m20 engine, it does not have variable cam timing. the adjustable cam gear can only be set when the motor is off.
          Unlimited Slip Diff's FTW!
          1972 240z Drift,Scca BSP, Scca ITS Car.
          • rwh11385
            lance_entities
            • 18403
            Originally posted by nando
            shrick or catcam. stay away from regrinds (ie racetep). also, I wouldn't go with anything less than a 284, it will idle just fine and make a bigger difference than a 274. a dual pattern is even better, my idle is pretty smooth with the 284/272, and I love the way it lopes. I kinda wish I'd have gone with a 288 or more, but I know I would have regretted a 274.
            if i were going for a cam ever, as a fun car, it'd be a dual pattern one.
            for KP, i might go 288, or may still go for a 284/274
            Ted ran one too
            Originally posted by SlammedE30
            Correct, thanks Chris. It's got an Ireland 3.0L stroker kit, Pauter rods, a Schrick 284/272 cam, mild headwork, 9.8:1 pistons, custom Borla exhaust, 21.5# injectors. That's the major stuff, and I have a Stahl header on the way. Hope that answered your question.
            -Ted
            • rwh11385
              lance_entities
              • 18403
              Originally posted by Stu Mc
              Why install such a mild cam? A 272 or 274 is only a little hotter than the stock cam. Go for a 284/272 or something similar, the dual-pattern should work well with a low-torque load engine.
              For a stroker, especially a 3.0L, look into something like a 288 or 292.
              • Low Level E30
                • 1646
                Ted ran one too
                How 'bout a DBilas 282/272? Very cheap over here...
                Do I need new valve springs? OE or upgraded?
                • rwh11385
                  lance_entities
                  • 18403
                  PM nando
                  • MrK
                    • Jan 2006
                    • 709
                    I have an adjustable cam gear, but it's only because I decked my block and used the cam gear to get the timing aligned again, not for the cam itself. I did put stiffer valvesprings as insurance, and I recommend that you do too. Of course the tamer the cam, the less likely you'll need stiffer springs.
                    Performance of the car changes totally with a 304/304 cam... you lose major low-end torque, but high-rpm power jumps significantly. You'll end up with a peakier (but IMO more fun) engine.
                    No, there's no 'on-off' switch per se, but you'll be able to feel a cam start breathing around 4 to 5k rpm, depending on what cam you choose. Mine comes alive at 5k.
                    • Low Level E30
                      • 1646
                      Probably no need for the cam gear on a stock motor w/ a 282/272, huh?
                      I will probably just use new OE springs --- I've heard that stiffer springs can cause cracking in these heads.
                      This will be for a track car anyway, so I ain't skeered of the low-end Tq loss :D
                      • MrK
                        • Jan 2006
                        • 709
                        With a 282/272 you'll be fine with new OE springs. Enjoy :)
                        • Low Level E30
                          • 1646
                          In that case... anybody wanna buy an adjustable cam gear :D ?
                          • MrK
                            • Jan 2006
                            • 709
                            If I'm not mistaken, both diegom6 and digger are in the market for an adjustable cam gear.
                            • nitro325is
                              • 495
                              On one of my cars Ive got a BMP 282/272 cam with their HD valvesprings for insurance because that cam is high lift 11.5/11.0 ......so check your spec as well. I wouldnt trust oem springs with that.
                              You can feel it come on at 4000 rpm feels great especially on a highly modded engine like mine.
