i have a 1984 bmw 325e that i bought as a no start and replaced the starter and after that the car starts but then shuts off, i detected that it wasnt getting voltage to the fuel pump that goes in the fuel tank so i decided to replace the fuel pump relay and it still does the same thing, and their is some wires that are under the dash that are the same color as the fuel pump wire (green and purple) which I think might be causing the failure but not sure if anyone knows what this might be please comment, thank you
Fuel pump problem
Tags: None
Stuck shut or simply clogged main injectors from long standing and old fuel. 7th cold start injector sprays enough for engine to start, but rest of the main 6 don't supply enough fuel or any for continuous running. That was my problem with 323i from 1983, that had been sitting in a shed from 1995 to 2012.My transaction feedback on r3vlimited :):Clickety clickComment
