My engine on my 92 325ic is shaking when I give it gas. Doesn't seem to matter if it's in neutral or driving down the road as long as the rpms are up. It'll immediately stop if I slide into neutral and coast while rolling.
Engine shaking when given gas.
Those are solid mounts....Is your idle fine? When you give it gas and you're in neutral, the engine shake gets worse? I want to make sure there is a difference between having solid mounts, and an actually problem. Is the shaking feel like when the engine is about to stall?
To me, it sounds like a balance issue. Is your harmonic balancer on the front of the motor loose?1997 Artic Silver M3
CES GT4094r 651hp/615tq @ 24 psiComment
