Hey r3v I got up to go bleed the air from the coolant system and to hook up my h4's, and my 1989 325i won't start. I had the battery charging because some coolant was making the alternator belt slip but that was a while back, everything is dry. It's an m20. I did the diangnostic plug test and to bypass the ignition wires, and this is what I got. I've been looking at lots of sources to determine why my car won't start but does this one definitively mean it's the starter, or could there be other things happening? After I try to start it the red oil light comes on too, and I read that this may not allow the engine to start, would an oil change fix this? My oil doesn't smell like gas so I don't think it's leaky injectors. The car has over heated before but that was a long while back and it has started well since then probably at least 30 times. Could a BHG make oil leak and then send a signal to the oil pressure light? https://vimeo.com/124754582
I tried to get a pic, there is some oil buildup around the head on the passenger side, could this determine a BHG? These pics are right below the exhaust manifold/headers.
ANY help is more than welcome! She was getting so close to being on the road, and this happened! Also I have a bentely manual in the mail so if there are any pages I should reference when it comes that would be awesome too!
