This is a strange one. My sons 89 325i seems to have developed a weird problem during hard acceleration when the car is not yet up to temp. If you push the go pedal to the floor and let the rpm's get in the upper range the car will suddenly lurch for a split second and then continue on as if there was nothing wrong. When this happens the CEL will flash on for as long as the car seems to be electrically dead. This only happens on a cold engine and gets really noticeable with the AC on. When the compressor first kicks in that extra load seems to make the engine halt for that split second until the engine is fully warmed up. With the AC on though it will do this at lower rpms too.
I am thinking maybe the AFM is bogus at full throttle, but that doesn't explain why it would happen with the AC on and at lower rpm's. Also suspecting maybe the crank sensor is on its way out as this seems to be a definite electrical problem. A fuel problem would not cause the engine to stop running for only a split second IMO, especially because I can hear the fuel pump running and even if the fuel pump cut out for that split second the rail and injectors would have fuel and pressure still during the time it fails.
Also could be a bad main relay too I guess, but that doesn't make much sense to me either. If it was the relay then the car wouldn't start to begin with and the fuel pump wouldn't work.
The car runs fine otherwise and idles great as well. Sometimes is hard to start the warm motor and I suspect maybe some slight injector leaking as the cause of that problem as it will fire right up if you push the go pedal down a bit while cranking. Any thoughts on the subject would be greatly appreciated. It is hard to describe such a peculiar issue, but I hope someone will have enough info to help me figure this out. Thanks as always!
