Firstly, the car is a 1985 325e. Other possibly relevant information is that I recently raced a rallycross with it which was extremely muddy. Like, a foot deep kind of mud where people were consistently getting stuck. Everything went well and it ran like a champ.
Then the other day I was driving it to the gym and all of a sudden it sputters out and dies, acting like its running out of gas, which seemed possible given my non-functional fuel gauge. I poured some fuel in but it just cranked over until the battery died. Awesome. So I towed it the few blocks home with my STI with a 6,000 lb strap which promptly broke and I had to rig back together.
Anyway, I start looking into the fuel pump and poking around. All connections look good. I decide to randomly try to start it with a charged battery. Boom, starts right up. I thought this was odd but thought maybe it had run out of gas and it took a bit to get fuel through the lines, however unlikely.
This brings us to Sunday, when I took it 75 miles out of town to go for a hike. Brilliant, I know. It ends up doing the same sputtering and dying thing, but I know it has fuel. I brought a handful of tools, test light, and multimeter in anticipation of this. I quickly realize that I'm getting no power to the fuel pump. So I look at the fuses and they're all fine. I then look to the relay and I'm not getting power to any of the pins of the fuel pump relay. So jumping pins won't start the fuel pump. I jumped two pins on the DME relay and the fuel pump relay at the same time and the fuel pump ran but it still wouldnt start.
At this point I decided I must not have spark so I checked the coil, and sure enough, no power to the coil. Fantastic. At this point I'm running out of battery from trying to start off and on and I didn't know you have to bridge three pins on the DME relay so I have it towed (Thanks AAA).
Immediately I swapped in a DME relay I had from a parts car and I am now getting power to the coil, but still not to the fuel pump or fuel pump relay. I gave up for the night.
Yesterday, I thought I'd crawl under to see if the wires to the CPS sensor(s) were severed by a rock or something. All the wires looked fine but the sensors were coated with mud. I picked off a bit of the caked on mud and decided to work on it later but before I went inside I cranked it over and it started immediately like nothing ever happened.
So really, would a moderate amount of mud interfere with the CPS sensors? I can't make out how that would work. Could it be that the old relay as well as the spare one I swapped in are both working off and on?
I don't think it's a problem with any pumps themselves because the problem was getting power to them. Any insight?
Thanks for any help and sorry for the length of my post.
I don't think it's a problem with any pumps themselves because the problem was getting power to them. Any insight?Thanks for any help and sorry for the length of my post.
