i noticed when the flap is "closed" there is still light coming through as it is not fully closed. Is that normal or should it be fully closed.
Afm question
Tags: None
I took a look at my spare which is known to be good. I could see light above and below the flap. There is a gap of about 10 thousandth of an inch so the flap can move freely. The air at idle is controlled by the screw under the blue cap which should not be messed with.
Hope this helps.Comment
Thank you sir.I took a look at my spare which is known to be good. I could see light above and below the flap. There is a gap of about 10 thousandth of an inch so the flap can move freely. The air at idle is controlled by the screw under the blue cap which should not be messed with.
