So while trying to figure out my no crank issue, I noticed the fuel pump wasn't turning on. I checks for voltages and noticed that the control side of the fuel pump relay wasn't grounding through the ecu. the main relay control circuit is grounding through the ecu and operated correctly. the ecu should ground the relay at KOEO, but doesn't, is this leading to a bad ecu or is there another way to fix this without having to find an ecu?
Thanks
Thanks
