So I recently purchased an e30 that had been sitting for "2 years" due to a bad starter. Their son had attempted to replace the starter but couldn't figure out why the car still wouldn't crank even with the new starter. Turns out he never hooked up the power wire to the new starter haha.
So long story short, I fixed the starter wiring and had to put a new fuel pump in the car to get it to start. I drained all the old gas and replaced the fuel filter. Upon starting, it runs like absolute ass. Sounds like it wants to die (and sometimes does), slight white smoke from the exhaust but nothing crazy.
Worried that it may be the head gasket, I did a cold compression test and got the results below.
Cylinder 1. 127
Cylinder 2 135
Cylinder 3. 100
Cylinder 4. 125
Cylinder 5. 120
Cylinder 6. 130
Do these numbers look ok? I have already purchased the head gasket and timing belt kit, but wanted some opinions before tearing into it.
Here is a video of the second startup. Also to be noted, the fuel pump is whining abnormally loud imo. Not sure why.
Cylinder 1. 127
Cylinder 2 135
Cylinder 3. 100
Cylinder 4. 125
Cylinder 5. 120
Cylinder 6. 130
