1990 325is, M20B25. Car was running fine yesterday and I decided to check the compression for a misfire issue I am troubleshooting. So I disconnected the positive wire on the coil, pulled plug wires & plugs, then pulled the fuel relay. All cylinders were fine, around 150. Put everything back together and went to bed.
This morning I was ready to go to work and the car just cranked, wouldn't start. Checked everything I disconnected previously, jumpered the fuel pump relay and the fuel pump worked.
What could it be? It cranks fine, just sounds like no fuel. If the jumpered pump works does that mean it could be the relay? would disconnecting the relay and plugging it back in fry it?
