need help with hoses
  • jakestyles
    • Dec 2014
    • 2
    hey guys i drive an 87' 325es
    i need some help on where all the hoses go, throttle body and where thermostat is. i have looked and researched everywhere and i cant get a schematic or a print on anything.
    i need to know where the hose from the canister (near master cylinder) goes and also the two bottom hoses from the thermostat.
    i cant find it anywhere.
    thank you
  • Reichart12
    • Aug 2012
    • 2165
    Try Realoem.com
    If it wasn't raining right now Id go look for you because I don't know for 100% but heres a diagram from that website. Should help you line things up more.
    Instagram: Reichart12
    • long tall eta
      • Jul 2010
      • 1536
      this one is specific for your e car.
      eta cooling by robert_elliott54, on Flickr
      • Reichart12
        • Aug 2012
        • 2165
        Should be the same diagram, both versions are shown for me under the settings I have giving the 325i title.
        • turbo55
          • Jul 2014
          • 223
          For the canister (note these are fuel hoses):
          -a hose comes into the canister from the hard plumbing coming from the gas tank (this is for gas vapors for evap control)
          -a hose comes out of the canister and to a solenoid valve (which also has a electrical connector going into it to activate the solenoid) and from the valve there is a hose going right to the bottom of the throttle body
          Throttle body (coolant):
          -hose coming in is from the very back of the engine, right under the #6 intake
          -hose coming out goes to the thermostat housing
