Help! Stranded
  • bbs_s52
    • Mar 2012
    • 110
    Help! Stranded
    Quick info: 87 325is
    Alternator belt chewed itself up stuck on the side of the freway. Have an extra belt thank god. What's the easiest way to get this thing on! Do I have to remove the fan?
  • Kvasi
    • Apr 2011
    • 1122
    No, loosen the alternator and put the new belt on. Its a 2 min job.
    • bbs_s52
      • Mar 2012
      • 110
      What about the belts in front of it? Do I have to remove those too?
      • spdracrm3
        • Sep 2009
        • 959
        yes you have to remove other belts to get new Alt belt on
        if your in a hurry and cant get under car , you can sacrifice other two belts by cutting them to get them out of the way and then just put new alt/wp belt on (slip Alt belt over fan first) to get you home (wont have AC or power steering ) but at least you'll be off the freeway and if alt belt failed other belts probably need replacing any way
        Angus
        88 E30M3 X2
        89 325IX
        92 R100GS/PD
        • estoguy
          • May 2013
          • 1087
          Good rule of thumb is to replace the v-belts when you do a timing belt, since you're in there anyway. Before my E30, I followed that rule with all my VWs and never had a V-belt or serpentine belt break in service. And I've had my E30 for 2.5 years and over 150K km, and two timing belt changes with no belt issues. Unless you install them wrong or they get damaged somehow, the V-belts should last through the lifespan of a timing belt.
          Estoguy
          • bbs_s52
            • Mar 2012
            • 110
            Thanks Man! That's what I ended up doing to get me home for now
            • bbs_s52
              • Mar 2012
              • 110
              I just had everything replaced about 10k miles ago
              • estoguy
                • May 2013
                • 1087
                Bummer dude... what brand were they? I've always used Conti belts all around, no problems.
                Estoguy
