Can I use the old parts?
  • mexocutioner
    • Apr 2015
    • 113
    So my motor threw a rod, the car still drives but I stopped driving it. Im buying a junkyard motor, that I really don't know anything about but its whatever at this point.
    Can I use the water pump and timing belt from my blown motor on this "new" one? they only have 4-5 thousand miles on them as they were just installed. Are they good or are they screwed from the blown motor too?
    I also want to get all new gaskets for it while the motor will be out. What are all the new gaskets I should get, and what other parts should I just go ahead and replace while the motor is out? thanks guys
  • 101
    • Jul 2011
    • 764
    water pump - yes.
    timing belt tensioner - yes.
    timing belt - NEVER!
    With a junkyard motor, I highly recommend getting a compression check and cylinder leakdown check done and peei=king under the valve cover for sludge and cam wear before making any decisions on what to do next. That will tell you a lot about the engine's internal condition. Also look for obvious external oil leaks. If it has low compression or other problems its far easier to rip into it on an engine stand rather than once it is installed in the car.
    Also depends on your ownership horizon. If this is a "forever" car I would replace every seal and gasket on the motor. If its something you're going to keep for a year or two or three, I'd take a cheaper approach.
    101
    The E30 collection:
    1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
    1987 325is - Delphin / Black Sport (son #3's)
    1987 325i Convertible - Triple Black
    1989 325iX Coupe - Diamondschwarz / Black Comfort
    1990 325iX Coupe - Sterling Silver / Grey Sport
    1981 Fiat 124 Spider 2000 - Green / Tan
    1998 Volvo V70 GLT - White / Tan
    1998 Volvo S70 T5 manual - White / Taupe
    2001 Ford Windstar - Silver / Grey (parts hauler)
    2006 Lexus GX470 - White / Tan (tow rig)
    • mexocutioner
      • Apr 2015
      • 113
      Okay. the place im getting the motor from doesn't do those tests, but they check to make sure it runs at least. Are these tests easy to do when the motors pulled, or should I just have a shop do this?
      What does a correct compression check and oil leakdown check look like?
