Hello all,
Tried to fire up the car with no avail last night. I followed the directions on the swap guides to the T and the C101 is wired up correctly, all grounds have been checks and are good.
- Starter works, motor does not turn over
- No spark
- Coil gets 12v
- Fuel pressure is good, no fuel coming out the injectors
- Maybe the ECU isn't turning on?
May have something to do with the white/black dangleing plugs near the ECU. Usually, fuel pump would only turn on when trying to start, gave one of the pins some 12 volt and now it turns on with ignition. Which is correct?
And there is one plug that I am not using that I can't figure out what it is for, its the black plug laying on the booster in the below pic. There are 3 plugs directly near it, one for the throttle body, one for the AFM, what is the last one for?
- No spark
- Coil gets 12v
