Originally posted by Andy.B
View Post
IIRC, e30's DO do that. There is a wire connected to the shift selector that informs the DME when it is in neutral/park vs D/R. It was a while ago that I did a manual swap, but I should have some info here somewhere...
Edit: It looks like OP found their issue anyway. That's what I get for not reading to the bottom of a thread first.
View Post
I worked on figuring out the wiring differences between the auto and manual transmission, while also sorting out how to make sure cruise control still works. It was actually easier than I thought, but pretty much every auto -> 5speed swap guide I read was incorrect (at least for my car), or made it harder than it needs to be .
First off, although I never have any intention of converting this car back to an automatic transmission, I avoided cutting or hacking anything in a way that would prevent restoring it to its original condition. For the wiring, that meant cutting the harness off of the shift selector side of the connector instead of the car harness side.
Then I modified the shift selector side of the harness to make it a plug in adapter. To do this, cut the harness about 4 inches or so past the range selector connector to create a pigtail harness.
The harness now has 5 wires:
Brown (ground for indicator light)
Green/Black (Park/Neutral signal)
2x Green/Yellow (Hot on run or start)
Blue/White (Reverse light)
To modify:
Connect 1x Green/Yellow to Green Black
Connect 1x Green/Yellow to either one of the two reverse light harness wires
Connect Blue/White to the other reverse light harness wire
Cap off the Brown wire.
I used heat shrink tubing to make it nice and tidy.
This modified harness provides the signal for the manual transmission reverse light switch, and the Park/Neutral signal to the ignition relay to allow the car to start.
For bonus points, cut a car harness side C301 from a parts car to wire into the modified selector range pigtail to connect to the manual transmission reverse light harness, making it a truly plug and play job.
That's it at the shifter, but there are two wires that need to be tracked down and disconnected. The Black/Green wire that provides 12v when in Park/Neutral goes to the DME and Cruise Control module as well.
One of the Green/Black wires goes to the DME harness to a Blue/Red wire, and provides the DME with 12v when in Park or Neutral. This 12v signal tells the DME to correct the idle speed for the engine load imposed by the torque converter when the transmission is in gear and the car is stopped. If you disconnect this on an automatic car when in gear, the idle bogs down. Since we don't have a torque converter putting a constant load on the engine, we don't need this function anymore.
Simply unplug the Green/Black wire from the Blue/Red wire coming out of the DME harness, and tape them up out of the way.
The next wire to disconnect is the 'cruise enable' signal wire (connector C143) from the cruise control harness. The ETK wiring manual states 'For manual transmission C143 is taped to cruise control harness'. C143 is located under the ABS computer on the driver side. The Cruise Control harness side is Blue/Brown and on the car harness side, you will find another Green/Black wire that come from the auto transmission gear selector harness). All you have to do here is disconnect wires and tape them up.
My phone died before I could get pictures of this connector.
What you are left with is a single Green/Black wire in the car harness telling the starter relay that the automatic transmission range switch is in Park/Neutral so it can engage the starter, even though the the range selector is now gone. The DME does not need this signal, since it isn't an automatic car anymore, and the Cruise Control won't work when getting this signal.
The effect of the modified wiring pigtail is picture below... it's really much simpler than it's made out to be:
* I haven't verified the cruise control yet due to a faulty cruise control system, but considering the ETK tells you it should be taped out of the way on a manual car, that one is pretty obvious.
*According the the diagram, the Brown/Red wire coming out of the DME harness next to the Park/Neutral signal is unused. This is not true (at least on my car). It provides the speed signal to the instrument cluster through a Blue/Yellow wire that runs through the dashboard, and plugs into the green connector right next to the Cruise Control's speed signal wire at the cluster.
There you have it. Without cutting anything on the cars harness, you now have the car working as if it was equipped with a manual transmission from the factory. If anybody, for whatever crazy reason, decides they want to swap back at some point, then all they have to do is reconnect those other two Green/Black wires.
To modify:
