sputtering/dying under load 110+ temps
  • Vincent Brick
    • Feb 2013
    • 879
    I just drove from San Diego to Lake Havasu, several hours of driving in 110+ temps. I almost got to Havasu when the car started sputtering at anything other than idle. I let it cool off and it ran ok again, but another 30 min later and its doing similar. It will mostly idle and handle light load, but a little more throttle or a lower gear and it sputters. I thought fuel pump, my BMW mechanic roomate thinks AFM. Anyone have any ideas what it could be, or my best bet for getting back to SD tomorrow? Should i just cut my trip short and try to leave very early morning, and hope i can get back to SD before it gets too hot? Thanks for any insight.
    1991 325i Sport - Calypsorot Metallic - DAILY DRIVEN
    WTB in SoCal: 8"/10" Lukebox, leather Sport steering wheel, 60L MotoMeter fuel gauge, Thule/Yakima roof rack
  • ak-
    • 12422
    See if the CPS bracket came a little loose and backed off the CPS.
    My car wasn't able to rev passed 3.5k -4k or so because of this.
    You wouldn't happen to have another e30 around you to swap parts with for testing, would you?
    1991 325iS turbo
    • Mr. Tasty
      • Jul 2011
      • 3421
      how long will you be in havasu for? I will be back there seeing family on Tuesdayish.
      2014 Alpine White 335i MSport
      (Daily Driver)
      Full Mperformance Aero
      KW V2 Coilovers
      VRSF Catless Downpipes
      • dnguyen1963
        • Nov 2011
        • 2651
        I think you have vacuum leaks when the engine gets hot. Check the aluminum elbows that go into the throttle body. They tend to come loose with a hot engine.
