I've tried searching for a similar issue and haven't seen anything that helped.
My idle has been fluctuating between ~400-1000rpm. Just yesterday I replaced the CTS, and just today the Fuel Pressure Regulator to no avail. I suspect a vacuum leak somewhere.
The reason I'm still confused: When I pull the vacuum line from the intake manifold to the FPR, the idle smooths out and it's perfect; how it should be. Runs and drives well with quick throttle response.
Pulling this line should create a massive vacuum leak, right? Why would it solve my problem pulling this vacuum line off?
