I had the same problem.
#10 fuse blew like 10 times even with testing larger amp fuses.
I am clearly a noobie BUT I can tell you how I fixed mine.
IF fuse 10 keeps blowing remove your shifter boot and inspect the wiring running through that area. It could be shorting against the metal of the shifter or just have a bad connection of some sort. That solved my problem after cleaning that area up. I can post pics tonight if needed
